[SOLVED] Sound Blaster Audigy SE (PCI)
ronb1955
161
Don't know if its the Sound Blaster Audigy SE card crashing or what but sometimes windows 10 freezes and buzzing sound happens.
This card is old I know, are there any newer card that will work with PCI slot..motherboard is Asus Z79-AR
Use the onboard sound card, and if possible, think about replacing all your system. I cannot justify your needs, but the thing is as of 2021, sound cards are becoming rare, and rare means expensive and for professional needs, and PCI is an old standard. So it is a dead end. But you can buy an USB sound card, there are cheap alternatives, and more expensive ones. Never tried one, so no recommendations.
