Sound coming thru speakers and earbuds using Y Splitter
ckshowtime
4
I have a Y connector connected to the audio port on a monitor. I have the standard audio cable running from the back of the desktop device into the one side of the Y splitter and my ear buds into the other half. Audio can be heard from both the monitor speakers and the earbuds.
I don't have this problem on another device, only this one. I have done all the standard things for this situation and I am now beating my head against a wall. Any help would be appreciated
Then only connect the earbuds to the Y splitter. or get rid of the Y splitter.
Whenever you use a Y splitter, and connect 2 different devices to it, it is going to send the audio to both devices. It is not capable of reading your mind, and then adjusting the connections based on what you were thinking.
Connecting only the earbuds to the Y splitter doesn't work because the audio is then not getting to the monitor. I am using a Y splitter because the desktop device is too far away to connect the earbuds directly. This works on a different device, same exact model. was hoping someone would have an idea I hadn't thought of. Thanks.
