Sound cutting out in high volume
Shadow777
236
5
18,695
Hi everyone , ive been having problems recently with my computer sound, sometimes when im playing games o watching videos and have the sound to the max (believe me its not increadibly high, so thats not the problem) the sound just like cuts off with a static-like sound and if i was watching a video on youtube i have to refresh the page, and in some games i must restart, and i have to lower the volume so it doesnt happen again also i have observed a red x in the sound icon in the toolbar when this happens, any help is much aprecciated
i dont thinnk its the pc problem check your speakers it often happens to m headies just need to re plugin it and it works great and yea it happens to me when its volume is high.
just re plugin the speakers
lower the volume
if this dosent help i think your speakers are almost dead
they are not speakers, they are headphones and it happens with anyone
oh bloody hell.. i think you guys are right, i switched to some other headphones to try out and they work perfectly, it only happens with my big one, any ideas of what has caused this? and or how can i fix them, also when i plug them into an iphone or mp3, android ,etc only one side works
Ok i just cut the jack from the headphones and found another set that was broken but had a good 3,5 jack so i soldered it to the ones that didnt work and now it works like a charm! 😀 it was the crappy 3,5 jack that was broken
