[SOLVED] Sound drivers - Audio card vs bluetooth vs graphics card.
Rukazu
27
Hello. I didn't know which one of the forums and subforums will be the most accurate to post this.
I have a question: I have a mother with onboard sound card with digital output, the graphics card HDMI and the bluetooth.
I use audio with this 3 connections. My question is: The realtek chip and its driver manages the HDMI and bluetooth audio? Or it is processed with their own drivers and own hardware?
I want to know how to get the best quality audio... My monitor uses the hdmi output, and the soundbar uses the bluetooth. Are they using the realtek drivers? Because the monitor seems to use an nvidia audio driver, with a noisy sound.
All three are using different audio drivers?
HDMI output (from an Nvidia GPU) will use an Nvidia HD Audio driver.
BT will use it's own audio driver
Your Realtek onboard sound/driver, only has any direct involvement with the onboard, physical outputs from the motherboard itself.
Thanks, it was my doubt.
3.5mm and digital : realtek driver
hdmi output: own nvidia driver (and audio chip i understand)
bluetooth: own and independent.
So, my integrated audio chip does not have any relevance on the monitor and bluetooth sound quality...
