Sound From Headset Is Cutting Out
Rainbow_4
Commendable
May 19, 2016
9
My sound on my headset cuts out whenever I talk to someone via skype or discord. Never happens when just browsing the web or playing games. There is a short term fix for this, I go to Control Panel > Device Manager > Sound > Right Click On My Headset > Then Click Disable > Then Re-Enable. That is a short term fix, but probably 10-20 minutes later it cuts out again, then I repeat the process.
Is this a laptop? Try going to your manufacturer's web site and updating/reinstalling the audio drivers.
And personally, if the headset has its own software/drivers, then I would uninstall them, uninstall the audio drivers, reinstall the audio drivers, then reinstall the headset's software/drivers.
I have a PC, and I will try and go to my manufacturers website, It has there own software and drivers, but I've tried uninstalling the drivers then re-installing them for my headset. I will try to update it though.
I installed one of the drivers, I will see if it works, if it happens again, ill post on here. Also, my sound in my headset only cuts out when I use my microphone which is very odd.
