Sound is removed
In my sound playback, and all the other tabs it says " No audio devices are installed" how do I fix this? I didnt delete anything.
Check Device Manager see if the audio hardware is there with no errors. If it's there, try uninstalling it, go to the computer vendor support site and install the audio drivers from there. Can try checking for a newer BIOS and running that update as well.
