HI everyone! Here's one for you. Recently and all of a sudden my speakers stopped working. They were old so I replaced them thinking it was the speakers. The reason I thought it was the speakers is because the dxdiag showed no problems with my sound card. Also, the device manager showed no problems with my sound card. Also, when I open the volume mixer I'm showing sound output (green bars moving up and down). However I'm not getting any sound to my speakers.
I'm also using a headset (the analog inputs are connected to a USB cable) that are connected via USB. I pulled the analog green plug and put it into my soundcard on the back of the computer and there was no sound to my headset. SO, I took the analog green plug from my new speakers and plugged it into the green port on the USB cable and voila, sound out of the speakers. SOOOO, something must be wrong with the jack on the sound card?? That's what I'm thinking. Probably need a new card but I wanted to check here in case I was missing something obvious!
Thanks!
Bob
Thanks!
Bob
