Hi I have searched for DAYS for a solution to this problem... It is driving me crazy!!
HP Pavillion dv6000 (specifically dv6915nr).
I'm sure it's some kind integrated on board audio.
Sound Icon (down in bottom right of windows taskbar) has white "X" in red circle and on a mouse hover it says "No Audio Output Device Is Installed".
Going to device Manager there is no "Sound, video and game controllers" folder to group to expand???[ Strange (to me).
Here's what i've tried:
Went to support page to update drivers at HP Site. Where I select Microsoft Windows Vista for operating system... Don't know what driver to download of:
■Conexant High Definition Audio Driver
■Realtek High Definition Audion Driver
■Conexant High Definition Audio Driver (later version)
So downloaded the most recent one. And, since have tried all I believe.
Anyway, when I download the driver and run it to install, selecting overwrite all files, it comes back and says: "Driver Installation Failed: Could not find the device for this driver."
Then, I will immediately get a Windows popup that says "This program might not have installed correctly" and then asks me to chose "Reinstall using recommended settings" -or- "This program is installed correctly". I Have tried both.
Then, just by reading other posts decided to search for and download (UAA Universal Audio Architecture). I have really no clue what this is but was going by what I was reading. However, I really couldn't find one that didn't say was supported by anything but XP (Using Vista) so I downloaded this one from here because it said it supported "windows (all)". It was a realtek audio driver of some sort and went through it's thing and prompted me to restart, which I did. No change
Please, can anyone give me a nudge in the right direction, Please!
I've tried all the above, I also used the HP Recovery partition and i'm sure if that's the same as a full clean install, but i even went through to that so i'm willing to try anything...
Thank you very much!!
