Sound Problems Help!
Charles Freo
54
Good Day to all,
i was having problems with my audio / sounds.
when i plug in earphone at front panel some application wont have any sounds,
and when i plug in earphones at the rear panel applications with sound at the front panel doesnt have sounds.
i wanted to only have 1 panel.. when i plug earphones / headset and everything would work as is
please help thank you
hmm more info about your pc would be good, motherboard, integrated sound or dedicated sound card, model of sound card, OS, etc.
however, if you happen to have integrated Realtek audio, I think there's an option that makes front and rear panels to provide different audio sequences, disabling it should make it to 1 panel as you want.
