Sound
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.win98.gen_discussion (More info?)
My 98SE seems to play sounds/songs okay apart from those in the sound
property box in which is says that each sound file is damaged and needs to
replaced. Please advise my how I do this. Bob
Do you have you Windows 98 CD, or the setup .cab files on the hard drive?
If so, try this:
Click Start> Settings> Control Panel> Add\Remove Programs> Windows Setup tab.
Double-click "Multimedia" in the list of components.
Uncheck Multimedia Sound Schemes, and Sample Sounds.
Click OK, then click Apply.
Then go back and add a checkmark back to those two boxes, to reinstall them, then
click OK, then Apply.
Insert the Windows CD when prompted, or direct the installer to the .cab file
location on your hard drive.
Glen Ventura, MS MVP Shell/User, A+
http://dts-l.org/goodpost.htm
http://www.microsoft.com/communities/conduct/default.mspx
"Bob B" <bob@hotmail.com> wrote in message
news:VwB9e.13748$DU6.12290@newsfe1-gui.ntli.net...
Well done Glee..it worked.....I had ticked the multimedia box to add but had
forgotten too uncheck first. Thanks again Bob
"glee" <glee29@spamindspring.com> wrote in message
news:%230QjbhhRFHA.2252@TK2MSFTNGP15.phx.gbl...
> If so, try this:
tab.
them, then
file
to
