SP2 problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Is there a newsgroup specifically for SP2 matters?
I have upgraded from SP1 to SP2 using the MS CD and have 2 queries.
(1) Where should I look to see if the system regards it as being installed?
My Computer | Properties makes no mention of it, or even of SP1 any more.
Where should I look and what should I see?
(2) When I go to the new System Update I am only offered SP1 as a
recommended Critical Update.
Is this normal, and what does it indicate.
Has there been a new critical update that I should see? I thought there had
been one since SP2 was released.
Everything seems to be working fine.
TIA
Brian Tozer
> installed?
Here are three ways to tell:
1. Contol Panel-->System-->General Tab. Screen will show what level of SP
you have.
2. Start-->Run-->Winver. If you have SP2, it will show.
3. Contol Panel-->Add/Remove Programs-->Scroll down to SP2. It'll be listed
there if installed.
David Nimon
dnimonREMOVE@##sympatico.ca
"KiwiBrian" <briantoz@ihug.co.nz> wrote in message
news:uwmH3wonEHA.3520@TK2MSFTNGP11.phx.gbl...
> had been one since SP2 was released.
> TIA
> Brian Tozer
