SPD not found...help please
terry
630
Archived from groups: microsoft.public.win98.gen_discussion (More info?)
Win 98SE
Re-formatted & clean install of 98SE
Installed office 2000
Nvidia graphics card.
Scandisk & defragged
I am passing this PC onto a friend but wish to ensure no errors showing etc.
etc.
I have a mystery "flashing" warning line appearing on every startup (dos
screen)as follow:
"WARNING!..SPD not found @ DIMMS 1 4"
(for info' there is a space between 1 & 4). Boot up continues hey preso!
without any key presses etc.
I have 2 x 128 Mb memory modules, which I have taken out & tried different
permutations in the 3 availble memory bank slots on the m/b.....still same.
The PC appears to work OK.
Would like to get rid of this gremlin if anyone can help please.....even if
it means a registry tweak?
TIA
"Terry" <terrybetts11138@hotmail.com> wrote in message
news:dd7h0h$r19$1@nwrdmz03.dmz.ncs.ea.ibs-infra.bt.com...
> screen)as follow:
This DOS error message is presumably called
by either AUTOEXEC.BAT or CONFIG.SYS
(both legacies from MS-DOS and Win95)
which Win98 does not require. Try renaming
both so they do not run, boot Windows, and
post again here if there is any malfunction.
Don Phillipson
Carlsbad Springs
(Ottawa, Canada)
Unlike Ingeborg, I never heard of SPD, don't want to hear it ever again,
& do not know whether one of the following will test it...
http://www.simmtester.com/PAGE/products/doc/docinfo.asp RAM tester
http://www.memtest86.com/ RAM tester
Thanks or Good Luck,
There may be humor in this post, and,
Naturally, you will not sue,
should things get worse after this,
PCR
pcrrcp@netzero.net
| Win 98SE
showing etc.
| etc.
(dos
| screen)as follow:
preso!
different
same.
please.....even if
| TIA
news:dd7h0h$r19$1@nwrdmz03.dmz.ncs.ea.ibs-infra.bt.com:
> Win 98SE
> showing etc. etc.
> (dos screen)as follow:
> preso! without any key presses etc.
> different permutations in the 3 availble memory bank slots on the
> m/b.....still same.
> please.....even if it means a registry tweak?
> TIA
SPD is a small block of flash memory in the DIMM module. In this memory the
factory stores some information about timing. I suppose the BIOS tries to
read the SPD to set the memory timing, and for some reason it cannot find
it. Try changing the 'Memory timing by SPD' in BIOS setup in some hard
values.
Thanks for the reply, but unsure of the wording and application precicely
"...in some hard values" ?
Terry
"Ingeborg" <a@b.invalid> wrote in message
news:Xns96AC9BD0C7C29abinvalid@216.168.3.44...
> > Win 98SE
> > showing etc. etc.
> > m/b.....still same.
> > TIA
the
> values.
Thanks for post Don
1) I do not have Autoexec & Config.sy "ticked" in my Start up settings.
2) Just in case I have renamed the 2 as suggested .....still the same prob'
3) In my root dir' (C:)I have also 2 files of Autoexec & config, but the
extensions were both ".tsh", so I renamed these also...still the problem
after re-booting
Terry
"Don Phillipson" <d.phillipson@ttrryytteell.com> wrote in message
news:ODx8WXBnFHA.3336@tk2msftngp13.phx.gbl...
> > screen)as follow:
> Don Phillipson
> Carlsbad Springs
> (Ottawa, Canada)
I am unable to find "SPD" referenced in my bios settings, hence unable to
alter any settings.
Terry
news:dd7omv$c2o$1@nwrdmz01.dmz.ncs.ea.ibs-infra.bt.com...
> Terry
> > > Win 98SE
> > > showing etc. etc.
> > > m/b.....still same.
> > > TIA
> the
to
find
> > values.
The replies in the discussions below may explain:
http://www.maxpc.co.uk/tips/default.asp?pagetypeid=2&articleid=10603&subsectionid=712&subsubsectionid=546
http://www.sysopt.com/forum/archive/index.php/t-17917.html
Glen Ventura, MS MVP Shell/User, A+
http://dts-l.org/goodpost.htm
> Win 98SE
> etc.
> screen)as follow:
> TIA
news:dd7q3n$4b9$1@nwrdmz02.dmz.ncs.ea.ibs-infra.bt.com:
> to alter any settings.
Search for memory timing options. With 'Hard values' I meant don't let the
system set them automatically. Choose the longest timings possible. (That
will be 3 or 4 clockticks per setting.) When the system is stable you can
make them shorter. When you have the specifications of the dimms you can
use that settings, of course.
Ingeborg
Appreciate your patience, but frustratingly I am unable to find any of your
suggestions in my BIOS settings.
Terry
news:Xns96ACB0CE99086abinvalid@216.168.3.44...
your
Is your computer from a manufacturer? Like Compaq, HP, or IBM. Because I
think that they disable anything like that in the BIOS.
You can find answers to things like this by doing a search on Google.com. I
found this explanation by searching on: SPD not found @ DIMMS
http://www.pcformat.co.uk/tips/default.asp?pagetypeid=2&articleid=10474&subsectionid=688&subsubsectionid=488
Regards
Ron Badour, MS MVP for W98
Tips: http://home.satx.rr.com/badour
Knowledge Base Info:
http://support.microsoft.com/default.aspx?pr=kbinfo
> Win 98SE
> etc.
> etc.
> screen)as follow:
> same.
> if
> TIA
Hmmmmm. That settles it, then, it's talking RAM, just as Ingeborg said!
(But I've never heard mine speak, & my BIOS doesn't appear to be even
listening.)
PCR
pcrrcp@netzero.net
"glee" <glee29@spamindspring.com> wrote in message
news:Oz1tMqEnFHA.3960@TK2MSFTNGP12.phx.gbl...
| > Win 98SE
showing etc.
| > etc.
(dos
| > screen)as follow:
preso!
different
m/b.....still same.
please.....even if
| > TIA
NO............purpose built by local company (CRAM)
Terry
"jkb" <nospam> wrote in message
news:#BjtwNEnFHA.3256@TK2MSFTNGP12.phx.gbl...
> your
"PCR" <pcrrcp@netzero.net> wrote in news:OKicrfDnFHA.240
@TK2MSFTNGP10.phx.gbl:
<http://www.tyan.com/support/html/memory.html#3>
I see. But I said I didn't want to hear any more! Anyway, this SPD
device seems to be read-only. It is unlikely the RAM testers can test
it, but ???. Also, it definitely appears to be BIOS related. Perhaps it
will require an updated BIOS to use it. Don't know. (My own BIOS makes
no mention of it, not even in the docs of the BIOS flash-- System ROM
Update #1.)
PCR
pcrrcp@netzero.net
news:Xns96ACCCAFA2843abinvalid@213.132.189.33...
news:dd7vke$5vv$1@nwrdmz03.dmz.ncs.ea.ibs-infra.bt.com:
> Ingeborg
> your suggestions in my BIOS settings.
> Terry
>> > unable to alter any settings.
>> let the system set them automatically. Choose the longest timings
>> possible. (That will be 3 or 4 clockticks per setting.) When the
>> system is stable you can make them shorter. When you have the
>> specifications of the dimms you can use that settings, of course.
I'm famous for my patience. I've rebooted and looked how it's called in my
own BIOS setup. In my BIOS (Asrock mobo) it's called 'SDRAM frequency'. It
gives me the choice between 100MHz, 133MHz and Auto. For Auto it needs the
SPD, I suppose. (SDRAM stands for Synchronous Dynamic Random Access Memory)
"PCR" <pcrrcp@netzero.net> wrote in news:e02nifEnFHA.3608
@TK2MSFTNGP15.phx.gbl:
Which software do you use to read your news? :)
Why?
PCR
pcrrcp@netzero.net
news:Xns96ACD2DF87E00abinvalid@213.132.189.33...
This is not a disk operating system (dos) message. Its an informational
message as a result of the bios findings of your RAM.
Doing anything in windows will do nothing to correct this message.
Not knowing anything about your PC, bios make and version including date,
and compatibility of the RAM with each other, and if the RAM is compatible
with the bios and motherboard, there's nothing to say.
This describes SPD in reference to it being missing: Since the message is
from the bios results of RAM, the message will be strictly as a result of
the bios. Therefore, the message won't be identical on all PCs with SPD
capability.
http://www.crucial.com/kb/answer.asp?qid=3760
Since this definitely a RAM/BIOS setup hardware question, you might check
here:
http://www.crucial.com/support/contact_forms/tech_support.asp
> Win 98SE
etc.
> etc.
> screen)as follow:
same.
if
> TIA
"PCR" <pcrrcp@netzero.net> wrote in news:u0hjykEnFHA.2852
> Why?
It seems I shouldn't try to make jokes in a (for me) foreign language. What
I meant to say is that your newsreader seems to use sound to pronounce the
newspostings. Else you couldn't hear it.
I'm sorry. Somewhere the joke got lost in translation.
LD...Thanks..no joy with your suggestions.
As I report here.....I have removed both memory sticks from the memory
banks, rebooted, but STILL the flashing SPD warning !!!
Terry
"Lil' Dave" <spamyourself@virus.net> wrote in message
news:u61h7tNnFHA.2484@TK2MSFTNGP15.phx.gbl...
> capability.
> here:
> > Win 98SE
> etc.
> > etc.
> > screen)as follow:
different
> same.
> if
> > TIA
I found this on the Crucial web site:
SPD is required in SDRAM that is 66MHz, PC100, and PC133 compliant.
Standards set by Intel and JEDEC ensure that data is entered in appropriate
locations so the motherboard BIOS can understand what this data means. The
SPD standard allows greater flexibility for incorporating identification of
new features and technologies on memory modules.
A lot of ram has a life time warranty so maybe a call to the ram maker is in
order. You also might want to try some other ram if possible.
Regards
news:dda9di$fcm$1@nwrdmz03.dmz.ncs.ea.ibs-infra.bt.com...
> Terry
>> compatible
>> is
>> capability.
>> here:
>> > Win 98SE
>> etc.
>> > etc.
>> > (dos
>> > screen)as follow:
>> > preso!
> different
>> same.
>> > please.....even
>> if
>> > TIA
news:Xns96AD61F636FDBabinvalid@216.168.3.44...
| > Why?
What
the
Ah, ha, ha! OK, then. Yea, that was funny. OK, bye.
