Speakers Buzzing after LED Strip install!
BigGameHunter
62
Hello I installed an RGB LED strip in my PC case today. I turned on my PC and heard my speakers buzzing like crazy! Does anybody know how I could fix this?
You should of had a little invert-er box that the led light strip connected to, and then you connected it your Psu via a molex power connector or a three or four pin fan header on your motherboard.
Either adjust the lighting strip, and where the invert-er box is, move it away from your motherboard or the main power supply unit of the system.
The other way is to seal the invert-er box in another box, lined with tin foil.
To create a shield to prevent electronic interference noise coming from the invert-er box that drives the led light strip.
What you hearing is EMI Electro Magnetic Interference.
I figured it was some sort of Interference... Could It damage my power supply? Just wondering because I have it sitting directly on top of it 😛
Ok thank you. I am returning it to the seller tomorrow. Is the NZXT Hue a better option?
