I am looking to build a PC for work. I do GIS (Esri ArcMap) and PC work and I need a fast system with a lot of memory, but I don't want to spend a fortune on Memory. I read that it is best to keep the memory speed at the recommended speed of the processor since the memory controller is built into the CPU.
With that said, DDR 3 1600 or PC3 12800 is what the INTEL CPU's run at, should I get faster memory? I am not up to date on current chipsets, so I don't know what is the best to get, but I want to get an Intel CPU with 6 cores.
The Motherboard needs to support at least 3 PCI slots. I have an OCZ Revo 3 x2 HDD, so I need a PCI x4 slot and I was looking at two Nvidia 770GTX video cards.
With that said, can anyone recommend me a CPU, Motherboard and Memory? I was looking at these components, but then I read a thread that said the X79 Chipset was old out running it's course. Also, I am not sure if socket 2011 is the way to go or a different one.
Already have:
OCZ RevoDrive 3 x2 (Boot Drive)
Looking at these for the build:
LIAN LI PC-A79B Black Aluminum ATX Full Tower Computer Case
Item #: N82E16811112412
EVGA GeForce GTX 770 DUAL SuperClocked 4GB 256-bit GDDR5 PCI Express 3.0 SLI Support Video Card 04G-P4-3774-KR
Item #: N82E16814130945
CORSAIR AXi series AX1200i 1200W Digital ATX12V v2.31 and EPS 2.92 SLI Ready CrossFire Ready 80 PLUS PLATINUM Certified Full ...
Item #: N82E16817139039
Arctic Silver 5 High-Density Polysynthetic Silver Thermal Compound AS5-3.5G - OEM
Item #: N82E16835100007
G.SKILL Ripjaws Z Series 64GB (8 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL10Q2-64GBZL
Item #: N82E16820231508
ASUS X79 DELUXE LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813132047
Intel Core i7-4960X Ivy Bridge-E 3.6GHz (Turbo 4GHz) LGA 2011 130W Six-Core Desktop Processor BX80633i74960X
Item #: N82E16819116938
CORSAIR Hydro Series H110 Extreme Performance Water/Liquid CPU Cooler. 280mm
Item #: N82E16835181035
Would this be a good system? Motherboard, I am unsure of. I would of liked to get the a GIGABYTE GA-X79S-UP5-WIFI but none in stock at Newegg and I have to purchase all the parts at the same place. They also didn't have the GA-X79-UD7.
Thanks for any suggestions!
Already have:
