Question Speed difference between two GPU
Pablo349
5
Hello, Im experiencing something that botters me. First of all I know these are old hardware but whatever....I have a GTS 250 512ddr3 256 bit, so I got something a little better, an HD5770 1gb ddr5 128bit.
The fact is, im playing CSGO and I have good fps with both, but with the GTS everything seems faster, although the same FPS. Since with the 5770 everything is slower. I mean, I have 60/+100 fps with both, but it seems all slower and Idont know why. I was asking if it is due to the bandwidth difference (128vs256). Can that make such difference? Or maybe its something else. Because on shooters it feels much better to move that faster. Thanks
Phenom ii x4 945 3 ghz
8gb ddr3
MSI880GME41
Pablo349
5
The HD 5770 is 1/3 to 1/2 again faster than the GTS 250. I wonder if the (used?) HD 5770 is defective. Run a benchmark like Heaven, Passmark, or 3DMark with each card and see what the results are.
Thanks for the answer, finally I vre read that the GTS has more texture rate (47.2 gtexel/s vs 34gtexel/s) Maybe thats the reason it seems slower even with more fps. Anyway I will test both with those benchmark
