Speedfan issues... or me being dumb issues?
THM01
117
Hello, I can't seem to control anything but one fan through speedfan (can control top back fan; see pic).
I have a total of four fans in my Corsair 760t (two in front connected to a usb bus of some sort since you can control it using a button on the chassis), one upper back fan, and a CPU intel stock fan.
Also, I assume there is a fan in the 750 watt power supply but no idea if that's controllable but wish it was since my PSU gets hot.
Thoughts?
Picture of what's going on:
pic of my speedfan setup
Some setups can support speed fan's fan controlling. I can only change my GPU Fan. That 102 degrees one I'm slightly worried about. If it stays at 102 degrees, even under load I think it's just a missing temperature sensor. What component is the "AUX"?
- Sam
Thanks for the reply!
No idea what the AUX is... I have an AsRock Z97 Extreme 4 mobo if that helps about supporting speedfan at all.
Any ideas?
Not really, sorry. I still think SpeedFan needs to update their compatibility stuff as I don't think it's quite ready yet.
- Sam
