Spoolsv.exe is using up to 80% of my CPU
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
I have latest version of Norton running and have swept for viruses. Also
have Spy Sweeper checking for spyware. Installed HP Business Inkjet1200
printer a while ago. I have checked print queues and nothing running. Have
stopped Spoolsv.exe process, but back it pops gobbling up more CPU. Any
suggestions?
> Also
> Inkjet1200
> Have
> Any suggestions?
Googling for this error produces a lot of links. Most of them come down
to either you have a virus or there are one or more print jobs waiting
in the queue. Some people mentioned that while the printer itself
showed no jobs, there was a job waiting on Microsoft Image Writer,
which I gather gets installed with Office. Since you are quite sure you
don't have a virus (and I assume that your latest version of NAV also
has the latest virus definitions installed), perhaps you have a job in
something like the Image Writer?
Otherwise, try clean-boot troubleshooting:
Clean Boot - http://support.microsoft.com/default.aspx?kbid=310353
and How to Troubleshoot By Using the Msconfig Utility in Windows XP -
http://support.microsoft.com/?id=310560
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
You might try seeing if HP has any new drivers for that printer. Often the
driver that ships with a printer is not the latest version by the time the
printer hits your print stand. It's like the thing with textbooks: the
delay between writing the driver and getting it from the factory to your home
may be a year or more, so the driver may not have been intended to function
with your current configuration.
> > Also
> > Inkjet1200
> > Have
> > Any suggestions?
> Malke
> "Don't Panic!"
> Often the driver that ships with a printer is not the latest version
> by the time the
> the delay between writing the driver and getting it from the factory
> to your home may be a year or more, so the driver may not have been
> intended to function with your current configuration.
Kathea has a really good point about the HP drivers. There have been a
*lot* of problems with some of the "extra" software that HP includes
with their drivers, such as monitoring software. I haven't seen the
100% cpu usage, but I have seen blue screening on some machines that
have the hpmon stuff starting with Windows. That's why clean-boot
t-shooting is useful in that case.
Malke
"Don't Panic!"
