SSD upgrade help
bnewlands32
195
I am running out of storage on my WD 1Tb HDD and wanted to add an SSD. I am on a budget so I was thinking get a 120Gb SSD as a boot drive and could have a few files on along with an additional 1tb HDD. I am on a budget, planning to spend around 100 USD.
Is this a good plan or should I get a 250gb SSD instead?Which ones should I get? How do I use an SSD as a boot drive If I currently boot of my HDD? Thanks for any help in advance! P.S. I put together a PCPartPicker list of What I might get here it is: https://pcpartpicker.com/list/d3qyNN
Then go for the 1 TB HDD and 120 gb SSD
It really depends, do you run more programs or games on your computer? Because some programs are gonna want to be installed on your SSD if you use your PC more for programs then gaming then go for the 250 gb SSD if not go for the 120 gb SSD and the 1 TB HDD.
I use it a lot for games. That's why I need more storage in the first place!
Why not a 120gb SSD and 1 tb hdd? comes to around $100.
Because I'm not a fan of 120GB SSD's anymore. They are getting to be 'too small'.
Yes, you can make it work. But they very often end up crunched for space.
I moved away from my 120GB C drive a couple of years ago.
