Starcraft 2 problem starting
honey2015
87
Graphich device is not available at this time. Please try Starcraft 2 again, or restarting your machine. etc...
I will try to post screenshoot exact image of that.
I have 5775C CPU with integrated graphic Intel Iris Pro 6200 (there is no dedicated GPU at moment).
I had try deleting "variables.txt" file.
had try reinstaling graphic driver
installed GPU-Z and it can see Iris Pro 6200 (I will put that picture also, somebody can tell is this normal specs for Iris Pro 6200)
in BIOS set iGPU as Primary (although it is only GPU here)
also I have adjusted VRAM for GPU in BIOS to 512MB (I heard 256 is minimum for SC2 and found this to be useful for some people with same problem).
but nothing works at all
pic host
screen capture windows 7
you mean Troubleshooting Video Issues ??
there is nothing useful at all
my laptop can run it, but as I remember, it is having problems running it at Ultra settings at singleplayer. it is i5-2410M, 2x4GB DDR3 1600MHZ C9, NVIDIA GPU 525M. maybe I can try to overclock 525M? :)
but I would be much happier to run it on desktop with Iris Pro 6200 it would run Ultra without problems
If you look at the list it does not have the Iris Pro 6200 in the list of supported graphics, maybe this is why the game does not detect a graphics card and giving issues. Have you made a ticket to blizzard? perhaps you can make sure you have the latest gfx/Motherboard drivers installed aswell?
tryed everything, and nothing works. DAMN ! this sucks really
overclocked 525M on laptop from 600 to 780 GPU Core, and memory from 900 to 970, all stable, temperatures are in OK range. looks like I have no other than play at 17.3" monitor 😀
