Stargate sound help needed
G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
I have sound when the game first comes on, but then it starts going in
and out and then its gone. Definitely not the pot or wiring I switched
them and they work fine in my joust so I am guess its in my sound board
anyone else?
Tim
When it goes out, have you tried hitting the test button on the sound
card?
If you get sound, the problem is upstream on the CPU/ROM board. I had
a Stargate that wouldn't play sounds, but the sound card was
good...Andre found and fixed it, it was a PIA chip of some sort.
Maybe this will help:
http://www.arcadesolution.com/help.html
<timb0pete@aol.com> wrote in message
news:1113672603.834748.303930@l41g2000cwc.googlegroups.com...
> anyone else?
> Tim
I have the same prob with mine, but in reverse, the sound only kicks in
after the game "warms up" about an hour or so. All connections good. I
think it's the switcher that's getting flaky.
Matt
> anyone else?
> Tim
very helpful as always Andre...you are the man. I will get back with
you on what I need to fix it.
Tim
ended up being the wiring going to the speakers...do you usually redo
the type of connectors on there currently or replace that with a
different style (molex) connector or something?
tim
