Starting to put together a new system, have a few questions
dragotx
40
Approximate Purchase Date:
Budget Range: As sub $1k as I can get but still have the features I want
System Usage from Most to Least Important: Almost exclusively gaming, with occasional bouts of photoshop thrown in
Parts Not Required: video card and case
Preferred Website(s) for Parts: amazon, newegg, frye's, tigerdirect, microcenter
Country: United States
Parts Preferences: I lean towards Asus and Intel, but as long as it's quality and reliable I'm happy.
Overclocking: Nice option, but not required
SLI or Crossfire: I will want to eventually run SLI with 2 GTX 780s
Monitor Resolution: Minimum 1080p, but I want to move up to 1440 or 4k within the next year or two.
Additional Comments: I currently run an i7-960 with 12gb RAM, 256gb SSD, and a GTX 780 on an Asus Sabertooth X58. I have had problems with my motherboard becoming unstable under heavy load for a while now, so I am starting to look into upgrading my system. I will be moving the 780, case, and SSD into the new system. I want something that is going to perform to at least the same level as my CPU without bottlenecking the 780 ( I think that is where some of my instability is coming from, it only happens when a lot of data is passing through the system). I want to eventually move up to an SLI setup with two 780s and run either 1440p or 4k, but that's at least a year away most likely. It's been so long since I've built a system I'm out of touch on which sockets are best these days, 1366 was the top dog back then. Should I go with 1155 or 2011, x77, x78, etc? My pc is primarily for gaming (it's not unusual for me to play Skyrim with Eve Online running in the background). I'm looking to buy anywhere between now and February (assuming my motherboard doesn't melt between then) depending on what is the best for the money. I know DDR4 is coming out reasonably soon, but from what I've read it's not going to be that big a deal for home use (sounds awesome for servers, but I don't really see needing more than 32gb ram at home). Right now I'm looking for ideas on what to look for really.
You could use this as a starting point for an upgrade:
z97 motherboards are the main things now, and 1150 is probably the socket to look for.
The i5 would probably do fine, you could go for an i7 if budget allows.
I'm assuming you'd be okay with overclocking, but I left the CPU cooler out because you could always just pick something that you like.
RAM, you don't need 16gb, but I threw it in there as something that you might be more leaning toward to compared to 8gb.
SSD and HDD you could recycle from your old build if you want, but if you want fresh ones, these would do pretty good.
PSU, EVGA supernova series are probably one of the best series quality wise for the higher end systems I believe. You could go with a EVGA supernova g2 850w, it'll support 2 gtx 780s and a i7 overclocked.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($229.99 @ Newegg)
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard ($203.99 @ NCIX US)
Memory: PNY XLR8 16GB (2 x 8GB) DDR3-1600 Memory ($149.99 @ Best Buy)
Storage: Crucial MX100 256GB 2.5" Solid State Drive ($104.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($57.24 @ Amazon)
Power Supply: EVGA SuperNOVA 1000G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply ($160.00 @ Amazon)
Total: $906.20
Can that i5 handle the games coming out right now (and for the next few years, i'm looking at a fairly long term system) at ultra? Obviously I would rather not break the bank, but I also don't want to get something that is just adequate for current uses and will need to be upgraded in a year or two to keep up with progress. The rest of the build looks great, I hadn't even thought about a power supply. My current one is 1000w, but it's also about 5 years old, and was an off-brand to begin with.
Here are some nice upgrade components to consider.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($339.98 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.99 @ Newegg)
Memory: G.Skill Sniper Series 16GB (2 x 8GB) DDR3-2133 Memory ($167.99 @ Newegg)
Power Supply: XFX ProSeries 1050W 80+ Gold Certified Fully-Modular ATX Power Supply ($159.99 @ Newegg)
Total: $954.18
Generated by PCPartPicker 2014-08-06 17:25 EDT-0400
