Hi, I recently built a pc and everything is going more or less fine except for a couple of issues, one of which I think must be a power supply problem.
Basically, when the pc is on there is no problems (except for one blue screen, but hopefully that was just a driver issue and sorted now). However, if i power it down for a while (say 30 minutes) i then have a lot of trouble powering it back up.
I think i've found a workaround by just powering down the psu for about 10 seconds and then rebooting, but still I would like to sort this out if possible, and also a little concerned I could be damaging other parts of the pc (is that likely?).
The power supply is a corsair TX 750W, and when I bought it I was told it was a good manufacturer and should be enough to power my pc...could this just be a faulty unit?
I think a blue screen i just received was due to a sound card driver issue (but didn't have time to get down all the message), but is it possible it could be also due to the power supply?
Cheers
Dave
Corsair TX 750W
Asus M3N-HD (nvidia 750a)
Phenom 9950 BE
XFX Geforce 260
4GB Corsair 1066 Dominators
Trust 7600 PCI sound card
190GB SATA Hard drive
IDE DVD RW
3 fans
Cheers
Dave
Corsair TX 750W
Phenom 9950 BE
XFX Geforce 260
IDE DVD RW
3 fans
