For web browsing and movie watching 60 Hz monitor is more than enough. 75 Hz monitor, in a small way, could be considered if you do play faster-pace games on it, which you don't.
Also, 15 Hz is so little increase that you can't tell a difference. For example, i had 60 Hz monitor and i upgraded to 144 Hz monitor since i do play games casually and i can hardly tell a difference. Faster games feel a bit smoother but other than that, not much difference in visible FPS. Though, biggest difference with my new monitor is color accuracy since i had TN panel monitor before and now i'm using VA panel monitor.
So, unless the 75 Hz monitor is cheaper or same price as 60 Hz monitor, there's no point going with 75 Hz monitor. Also, since that 60 Hz monitor is IPS panel and 75 Hz monitor is TN panel, you'd get a LOT better color accuracy and viewing angles with 60 Hz IPS panel monitor than 75 Hz TN panel monitor. Contrast ratio between the two is same and doesn't look good (max 1000:1). If you want better contrast ratio (e.g 3000:1), look towards any VA panel monitor.
Contrast ratio (richest/deepest blacks) is also one of the reasons why i went with VA panel monitor for myself since it helps a lot for my photo editing work. Color accuracy wise, VA panel is very close to the IPS panel monitors.
Long story short:
For your use 60 Hz IPS panel monitor suits better than 75 Hz TN panel monitor. Or you can look towards VA panel monitor if you want better contrast ratio.
