Double check the terminology you are using because most of it is wrong or you are royally screwed. Referring to things by different names makes communication incredibly difficult and trouble shooting impossible so double check the names that you are calling things.
The BIOS is the basic input output system on the motherboard, its what lets you select your boot order and change very basic settings about your system, if you board doesnt have one its a brick and wont work at all. Your HDD does not have a BIOS, it might have an operating system installed on it but it better not be storing your BIOS.
I think what you meant was that your new hard drive has an operating system installed on it? If you are getting a message that says "no HDD detected" double check the cables that run to it to make sure its plugged in properly. If that does not help resolve the issues, then post again with some more details, try to be as specific as possible.
