Hi Everyone!
Everytime I play half life( Counterstrike and Dark Messiah) , now and then I hear the sticky key sound. That one "beep" noise. After I hear the beep, I start moving in a single direction because I assume I sticked a movement key (wasd) I have to press the movement buttons to get it back to normal. I went to the control panel and am positive i disabled every check box under the stick key menu. EVERYTHING. Not one box is checked. Sometimes This happens also when i am not playing anything. When I hold down a key, it sometimes beeps. Not often though.
Any help is appreciated!
Im guessing this is a keyboard/setting/registry problem or something.
Before you say , press shift 5 times and uncheck use shortcut, Ill tell you one thing, I UNCHECKED everysingle checkbox there is in that stupid little menu and the herrendous beep wont go away!
