Question stop cpu going to 80 watts when at low load %
kamikazilucas
BANNED
Nov 15, 2014
124
i have my 5800x set to 90 60 110 ppt and because of that it peaks at 90 watts but even when using like 20% cpu usage it goes to 70 80% how do i make it peak at a lower wattage unless i go over like 50% cpu
What is driving the requirement for peaking at a lower wattage? Why? What are you trying to do?
Also - is there a reason for Freq #1 to be different?
More information needed.
Full system hardware specs and OS information.
PSU, Disk Drive(s)?
Reactions: CountMike
PSU, Disk Drive(s)?
litterally anything like opening chrome
So the requirement is, if I understand correctly, that the CPU's wattage be limited to some lower wattage unless the CPU usage % goes beyond 50%. Or some such scenario(s). More details needed.
What/why is doing so important? Is there some end objective expected by forcing some wattage to % relationships?
Reasons? Any reference links with respect to the stated wattage to % intentions?
And again:
System hardware specs, OS?
What about Freq #1?
Overall, unless there is some specific problem of any sort, I recommend just leaving the CPU, wattage, %'s, voltages, etc. alone.
