Hello,
I'm having a strange problem with a pair of DDR2 PC5300 (667) memory sticks. They're identical, from a 'generic' brand called TitanMemory, and I'm using them with an ASUS M2NPV-MX motherboard. If put them in the slots with the same color, they work in dual channel mode but memtest86+ report an error: always at the same address, only one bit is wrong and always is with test #7, all other tests are OK. If put them in the slots with different colors, so they work in non-dual channel mode, memtest86 doesn't report any error. It also happens with WinDiag: dual channel fails, non-dual channel it's ok.
This means that even the sticks are identical, they can't work in dual channel or it's a memtest86+/windiag problem?
Thank you very much
Thank you very much
