Question Strange fan problem
My GPU fans work on startup, work with benchmark but don't work with gaming or MSI Afterburner.. Any ideas?
Model please? Are you sure you edited the fan in msi afternruner? like make it from auto to 25% for example and see. If the fans aren't working even with using msi afterburner then it's faulty return it.
In gaming if your temps are under 60c the fans won't work (if you have a good card not the cheap ones)
Reactions: Dj0gany
10 degrees should run 100% fans but nothing. Why would fans work in benchmark but nothing else?
Latest posts
