G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.giga-byte (More info?)
I am wondering if anyone has seen these issues with the GA-K8NXP-SLI
motherboard.
I just bought and installed this MOBO and I did an in-place upgrade of an
existing WinXP Pro SP1 installation.
With the new OS installed, I have two problems:
1) The ordinary PS2 MS keyboard does not function at startup. The mouse
works but the keyboard is dead. I have to reset system and start SAFE-MODE.
Once in safe-mode I delete the standard "101" keyboard driver and I have to
force a reset as the system will not shutdown.
On the next boot the keyboard is OK.
Once in XP I must delete the keyboard driver on exit EVERY TIME or I have to
go through the SAFE-MODE boot.
2) The system no longer shuts down or re-starts. I must do a hard reset or
reboot every time.
The OS was fine prior to the new MOBO and video card.
I have noticed that there is no APM tab in the Power Options under the
Control Panel either.
The HAL appears to be correct as the "ACPI Uniprocessor PC".
The system:
GA-K8NXP-SLI
AMD Athlon64 3500+ CPU
MSI 6600GT PCI-X video card
1 GB DDR400 RAM (2 x 512 MB).
480 WATT PS
WD 160 GB Hard drive
MS Natural KB PS2
IBM Optical USB mouse.
Additional Zoltrix Video Capture card - PCI
Windows XP Pro SP1
Anyone have any ideas or suggestions?
Thx.
motherboard.
reboot every time.
The system:
GA-K8NXP-SLI
480 WATT PS
MS Natural KB PS2
Windows XP Pro SP1
Thx.
