All that remains is the pump and the motherboard
The components were selected by me, assembled in a computer shopSince when you noticed the noise?
Is your computer pre-assembled or you assembled it yourself?
The video card is old, I have no complaints about it.Try changing your refresh rate at monitor or windows settings and see if sound disappears/changes. My GPU has coil whine in almost every game, but it can be fixed by turning vertical sync on and changing refresh rate to 59/60hz and limiting FPS to 60. I honestly see no difference between 60 and 144.
UPD. But from what I hear on video, it sounds more like one of the fans, or vibration caused by them if you are sure fans are okay. No idea if it's something about your water cooling, but also could be it if you double checked the fans and it's not them.
UPD. I don't even hear squeal, more like humming, but nothing surprising since you put phone almost in the case and it just sounds like vibration. Or water cooling, though I never had an experience to work with PC with water cooling and have no idea how it should sound.The video card is old, I have no complaints about it.
I bought a 4070 oc version a week ago and it was a nasty coil.
I disconnected the cooling for seconds, removed the video card and attached the hdmi cable to the igpu, and still there was a soft hiss.
By the way, this is idle mode, I'm not playing anything at the moment
990 pro 1 tbBy sound, do you mean that squeal or those clicking noises? And did you disconnect ALL cooling at once? Soft hiss may be present anyway, since electricity is flowing through the PC, especially if you have SSD, they are not entirely silent like some people think.
I have same SSD and it makes louder noise than just soft whistle, you can even check on youtube how these sound. Rattling though really sounds like fan, so did you try stopping every fan one by one and check if sound goes away?990 pro 1 tb
Every component is under warranty without the video card, it is the oldest.
Well... Like the rattling of a fan rotor, and a soft whistling sound
You know what's bad about the whole situation?I have same SSD and it makes louder noise than just soft whistle, you can even check on youtube how these sound. Rattling though really sounds like fan, so did you try stopping every fan one by one and check if sound goes away?
I have tested all fans.You can try to make a tube of A4 paper and listen with it closely to each working fan and it may help with finding the source. And was the rattling sound present after you turned off the cooling? And which one you turned off - CPU, GPU or case?
What's your PSU?I have tested all fans.
Of course, not that of the power supply, but if it was from it, the noise would be from the lower part
What's your PSU?
be quiet dark power pro 750wWhat's your PSU?
