Strange problem with x1900 CF + x1900xtx
jooha2
First post here. Got recommended by a friend to try my luck here 😀
The problem is this:
When starting a game (WoW, oblivion, Battle for middle earth2, etc etc) the image starts shaking. The entire image moves, very little but very noticeable, from left to right, all the time!
I have the official 6.4 catalyst installed, and the monitor works fine on my older rig with an 9800pro.
The new rig:
x1900 CF + x1900xtx
AMD X2 4400+
Asus A8R-MVP
4*512 corsair 3200 memory, normal timings.
WD Raptor 36GB
Hyundai L90D+
Any help or a hint of what to do would be most appreciated, as i don't really know what to do next.
[edit: spelling]
No, i have not tried 6.3 catalyst. Everything else is up to date..
I have tried 6.1 without any changes.
The 9800pro is running on 6.1 catalyst flawlessly.
I've heard about Omega drivers, is those worth giving a shot? And if so, where can i get them and which should i use ?
The PSU i probably not the problem, i'm using a Hiper 580W.
I have not tried to disable one card to see if the problem persists, thou i will do it asap, will report back here with what i found out.
Framework 1.1 currently installed. You recommend me to upgrade to 2.0 ?
definitely use .net 2.0
I have seen it improve a few "twitchy" things w/ the ccc. No show stoppers mind you, just little occasional wierdness things. Nothing like what you are saying but you never know.
I also never used omega, but lots of ppl swear by 'em.
Yeah upgrade to .net 2.
I got 1 computer with the omega drivers on it and it smoothed out a few little bugs on it. The other has Ati drivers.
