Strange shutting down issue
garyknowz1
29
It's a strange problem. When I fire up the system it starts and then anytime between the BIOS check and the Windows login, it voluntarily powers down. When that happens in that span varies. It also takes a long time to detect the HDD arrays. But if I wait a day or so. I can fire it up no problem. It lasts a few days, then powers down again.
It's acting as if something is overheating, but I'm sure what. I selected motherboard due to the timing of the issue, but I could be power supply, memory, or even HDDs. Any help tracking down the culprit is appreciated.
Oops! Sorry, I thought I put them in my side profile.
nForce 780i SLI
Q6600 2.4 ghz
2x GeForce 8800 GTS 512
4 gbs memory
850W Rosewill PSU
Zalman CNPS-9900A cooling
Edit: couple corrections
can you provide the model #'s as well? especially for the PSU. In the mean time. try going into bios and see what your temps are after a few minutes, just to be safe. I ran into a similar problem and the cpu was overheating.
I kicked the fan speed up a couple notches with SpeedFan. The Core temp are 42C, 45C, 38C, 38C respectively.
The PSU model# is: Rosewill Extreme RX850-D-B. I know Rosewill isn't the best, but was the only one rated to 850W within my price range.
OK so temps aren't an issue, good. At least the one you have has active PFC and is 80+. I would try another PSU to see if it fixes it. I'm not sure how long you've had it, but yours may be starting to wear out. Get it somewhere locally so you can return it, fry's for example. if that's not your problem. Other than that. have you made any changes to bios or disconnected/reconnected anything? just a thought.
Thanks! Yeah, it's going on 5 yrs now. I swap it out and report back later.
Could the PSU also be the culprit in the long detecting arrays situation? It's take up to five minutes to get through the boot up process.
