I have a Dell XPS 8100 running Win7 64. Day to day everything works fine, except that is until I turn it off (as opposed to sleep / hibernate). If it is ever powered down I need to carry out a convoluted start up process I discovered by accident. My procedure it to 1) unplug the mains cable, 2) hold down the power button until the flea / motherboard orange light goes out, 3) disconnect the 24 pin connector, 4) plug back the mains cable into the chassis, and finally 5) simultaneously hold down the power on button, spin the cpu fan, and reconnect the motherboard connection. (and yes I know that playing around inside a mains connected pc is hazardous...). Without this process (especially the manual spin of the fan) it won't start, bleep, spin or anything. The fan incidentally spins freely, and the power button works flawlessly in all other situations..
So clearly I have a problem. So my question is aimed at the more cerebral tech wizards; what might it be the issue - what is it that I am doing (draining the circuit, spinning the fan, etc that allows the system to function, and what component should I examine.
Many thanks in advance.
