My computer was working great and one day it crashed and just went to a black screen (never in my life has that happened). Later discovered CMOS battery was bad and replaced it; not just low voltage but I may have read a short on it w my Ohm meter. I may have misread it because later there was no short.
Since then I have been having booting problems and also noticed weird characters in the Bios menus.
I tried clearing the CMOS using both methods - pressing the CMOS clear button as well as removing the battery.
I also went as far flashing the bios using the Q-Flash utility. I tried flashing both versions that work for this board, and still the same problem. Even that utility in the bios shows weird characters.
Anyway to no avail..
Even after flashing, I still have the booting problems and weird characters.
It will not boot normally. It always goes to the 'Recovery' screen (below) after the screen with the Windows logo.
I can manage to select safe mode under 'advanced options' through this recovery screen and can boot into my OS and desktop -
Anybody have any idea whats happening w my Bios/CMOS and why I'm having problems booting up ?
The motherboard is an old - Gigabyte GA-X58A-UD3R Rev 2 with an i7, and my OS is Windows 10 Home.
I would appreciate any advice or even just a clue.
