Dexxly_uk Reputable Nov 29, 2020 99 3 4,535 Apr 17, 2021 #1 Hello yesterday i was on r6 and my pc crashed i turned it back on and bsod i got a new windows install and all my games are microstuttery and bugy i need help pls (im about to give up)
Dexxly_uk Reputable Nov 29, 2020 99 3 4,535 Apr 17, 2021 #2 side note games only get messed up passed 60 fps Upvote 0 Downvote
Dexxly_uk Reputable Nov 29, 2020 99 3 4,535 Apr 17, 2021 #3 and the bsod i got was kernel security check failure Upvote 0 Downvote
carocuore Reputable Jan 24, 2021 395 97 4,840 Apr 17, 2021 #4 What's r6? also what are your specs? Upvote 0 Downvote
Dexxly_uk Reputable Nov 29, 2020 99 3 4,535 Apr 17, 2021 #5 my specs are at the bottom and r6 is rainbow six 😀 Upvote 0 Downvote
Dexxly_uk Reputable Nov 29, 2020 99 3 4,535 Apr 17, 2021 #6 i also think it is a cpu issue because when i pump more voltage into it the problem starts to fade Upvote 0 Downvote
carocuore Reputable Jan 24, 2021 395 97 4,840 Apr 17, 2021 #7 Dexxly_uk said: i also think it is a cpu issue because when i pump more voltage into it the problem starts to fade Click to expand... Is the CPU overclocked? that board isn't made for overclocking, not at all. CPU temp should be under 85 ºC also... you're using only 1 stick of RAM right? that could decrease performance but not too much to make everything stuttery Upvote 0 Downvote
Dexxly_uk Reputable Nov 29, 2020 99 3 4,535 Apr 18, 2021 #8 My temps are about 69c at high load and my ram was doing fine before this bsod I had so I think it is bad hdd or faulty ram Upvote 0 Downvote
Dexxly_uk Reputable Nov 29, 2020 99 3 4,535 Apr 18, 2021 #9 Also it is not fps stuttering it is mouse stuttering and latency Upvote 0 Downvote
