Strip Out The Fans, Add 8 Gallons of Cooking Oil
jayh619
8
does anyone no how long a computercan lst doing this? like after six months of being submerged and the oil was rinsed out. would the computer still work without the oil? or would the oil would decrease the computer's components life spans? Or increase it?
G
Guest
Guest
ive seen some run for a year at 80 degrees C with out anything cooling the oil but with a zalman water cooler hooked into it to cool the oil it will run at 30c for as long as the cpu lifespan
logicmoo
"On the motherboard http://en.wikipedia.org/wiki/Motherboard in the area of the CPU base, the oil is responsible for increasing the capacitive resistance between the individual wiring. In short, the oil acts as a dielectric material. Since very high frequencies occur on the motherboard, the capacitive resistance goes down. Accordingly, this then influences (or tampers with) the digital signals, particularly in the area of the CPU base. After all, 939 pins are located there in a very tight space."
This is the first article I've seen mentioning the sealling of he base of the CPU. Other's some in the forums are concerned that there is not enough cooling flow under sockets.. since liquid is thicker than air it tends to want to create hotspots here. Air will swell and vent heat more. This article notes that they "had" to seal the base for stability. I understand the dielectic effect. But anyways for a socket 775 anyone know for sure what we should do?
creepster
56
Why not use mineral oil, or better yet, transformer oil? It would have better electrical properties than cooking oil, and probably better thermal properties, too.
davea0511
I can't imagine those leads are long enough to cause any kind of capacitance issues. Furthermore, I can't imagine that silicone is going to keep oil out of there for very long. Dozens of others have done this without sealing off the CPU with no ill effects. Pugetsystems oil computer for example.
Anyway, I'm curious about the long term effects. This project was started a couple years ago. Is the computer still running, or did they decided to can it. Seems like everyone that does this ends up draining it before it get's a chance to fail from oil-related reasons. Pity - It would be nice to have some data to see whether it really could be a viable solution for a silent PC that would last literally for as long as the cpu transistors normally last.
OnyxxOr
Another note on the silicone... I noticed the only long term oil setups use seemless tanks (i.e. no silicon sealing in the actual submerged part of the tank). I've done some research on silicone and the "service" temperature range is listed at -50 to 150 celsius. However, one can understand normal silicone usage is for applications that experience far lower in use and/or continued temperatures (Fish tanks, showers etc).
Before considering that I purchased a tiny (15 litre) fishtank for a low end setup that was built/sealed with silicone, so I guess I'll soon know xD (hopefully not by it falling apart and spilling oil all over my carpets lol).
I have an existing 3 foot tank which I intended using for my 'production' system which will be more than double the power in every sense :D - and big enough for a whole bunch extra cold cathode's and led fans (for the looks of course ^^). I may reconsider that after some testing.
I'll do my best to pop back and post on this new consideration to let you know how the silicone behaves under extreme usage.
Oh and another thing, on the mineral oil... in all experiments the folks mentioned difficulty in getting hold of mineral oil. I initially thought the majour problem would be in the fact that it's classed as a known laxative and any distributor would be hesitant handing over that much of it for legal or safety reasons. Turns out most people don't even know what it is xD!! That got me onto some research into it's common consumers, and in so doing found a bunch of alternative names for it, which I DID see at some stores.
I'll list them here for acedemic interest but please keep in mind that common or trading names may differ from region to region so ask the right questions (Low viscosity, high flash point, no electrical conductance) AND test it in a controlled outdoor enviroment on smaller (cheaper) components before going the whole way :) That said, mineral oil also goes by the following names:
White oil
Nujol
Paraffin oil (Not normal paraffin, like for lanterns, far as I know)
Baby oil xD (Yep, though I'm suspecting the fragrance additives may have some unwanted properties, probably mildly corrosive)
Anyways, happy modding for now
l8r,
OnyxxOr
G
Guest
Guest
now i can overclock the living daylights out of my machine, and use the heat to deep fry some fish. Increasing my enjoyment (and that of my computer), as well as shortening my life (as well as my computer).
G
Guest
Guest
Cooking oil will turn rancid rapidly when exposed to air and heat. It will stink.
Don't use a food-based oil if you do this.
G
Guest
Guest
why not use synthetic motor oil?, miniral oil has trace minerals that can stick to surface (non-conductive but it looks ugly)
G
Guest
Guest
motor oil would work as faras i can tell, im off to thestore to pick up all of my instruments needed to build the worlds fastest pc EVER! hahahahahahahahaha :devilish grin:
computabug
458
aww the links to the downloads are not working anymore :( Can someone post them up again, or even on some other host like Youtube? Wait, I should go check if it's already there first lol ^.^
G
Guest
Guest
A PC and deep fryer for my fries all in one machine. What happens if I use Petrol or Diesel instead of cooking oil? Will my computer go faster?
