Stuck in Driver Verifier iomanager Violation loop
I've looked at a couple of other forum posts on similar issues and the solution seems to be to boot into safe mode to turn off the driver verifier. but the problem is that I get the bsod before I reach the log in page, so it's impossible to get into safe mode.
Does anyone have a clue how to get out of this loop?
Hello again
In that case, you can try booting in Command Prompt using the instructions given here, and then fix the EFI bootloader or run the SFC /SCANNOW command from there.
Cheers!!
