[SOLVED] Stuck in Restart Loop, cannot open Safe Mode, system restore failed 0x80070020 (I think becuase of Skype). Only Command Prompt Works. Help!
Oct 31, 2019
Long story short. Windows updated and messed everything up, drivers weren't working so I did a system restore. But that never completed and now Windows in a reset loop. I tried everything recommended. Safe mode crashes, saving backups using command prompt results in 0 files with 0 data. When trying to do a system restore, this number 0x80070020 seems to be an issue. I read that is usually from Skype, which was just installed. Is there any way I can remove skype and fix that error. I feel that is the cause why nothing can be backed up, restore doesn't work and safe mode crashes.
Do I wipe the computer clean? Can I save my files somehow?
