J jacksonsftw Commendable Apr 8, 2016 2 0 1,510 Apr 8, 2016 #1 I have an msi motherboard, and in the bios i turned on windows 10 support, and everytime i boot, i go into a 'shell' thing, and the bios is glitched and not working, how do i atleast get the bios working and getting out of shell?
Solution popatim Apr 11, 2016 Apparently MSI has neglected to post that motherbds manual online or even drivers & bios updates... hmmm. You may need to take out some ram so yuo get the 'System changed' message 'press F1 to enter setup' where you can set EFi boot to disable
popatim Titan Moderator Dec 2, 2009 39,129 1,040 136,890 Apr 9, 2016 #2 Theres a setting in my msi boards bios to turn off the 'go to shell on boot' Let us know which board you have if you can't find it. Upvote 0 Downvote
J jacksonsftw Commendable Apr 8, 2016 2 0 1,510 Apr 9, 2016 #3 popatim : Theres a setting in my msi boards bios to turn off the 'go to shell on boot' Let us know which board you have if you can't find it. My motherboard is an msi h97 pc mate https://www.msi.com/Motherboard/H97-PC-Mate.html#hero-overview Upvote 0 Downvote
popatim Titan Moderator Dec 2, 2009 39,129 1,040 136,890 Apr 11, 2016 Solution #4 Apparently MSI has neglected to post that motherbds manual online or even drivers & bios updates... hmmm. You may need to take out some ram so yuo get the 'System changed' message 'press F1 to enter setup' where you can set EFi boot to disable Upvote 0 Downvote Solution
