Stuttering sound & games on a P4SGL-VM
Tim
1,833
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi there,
We have a P4SGL-VM which has just had a clean reinstall of XP Pro and when
we play a music CD using Media Player 10 or try and play a game which used
to work the sound or game just stutters all the way through.
Changed the CD drive thinking that could be at fault but it wasn't.
Any ideas on what could be causing this apart from this problem the computer
is working fine?
Many thanks, Tim.
In article <lEkae.17931$G8.574@text.news.blueyonder.co.uk>, "Tim"
<erat@NOSPAMblueyonder.co.uk> wrote:
> Hi there,
> is working fine?
> Many thanks, Tim.
IDE Bus Master Support [Enabled] ? I wonder why Asus was stupid
enough to make that disabled by default ? That setting should
be enabled instead.
It could be your disk/CD interface is dragging down the machine.
Bus Master support means DMA is available for your drives, and
that means you'll get more than 4MB/sec transfer rates associated
with polled transfer (PIO) mode. In Windows, you want
Device Manager to say "DMA, if available", to take advantage
of the BIOS setting.
PCI 2.1 Support [Enabled] is the default and should remain set
that way. The Delayed Transaction feature allows other PCI
transactions to occur, when slow Southbridge accesses would
otherwise hold up the machine, and leaving that option enabled
is a good thing.
HTH,
Paul
