[SOLVED] Subtitle unicode help
Ojimoji
124
Hi guys. I Want change group subtitles unicode from utf8 to ansi in win 10 . Is that possible ? With Witch software? Tnx for helping😊
I understand your reply to be that "Powershell" does not work for you.
Simple may not be possible with respect to your end requirements - likely that any "simple" solution will result in incomplete or inaccurate results.
Google "UTF8 to ANSI converters".
Check the following link:
https://www.dostips.com/forum/viewtopic.php?t=3922
Read the entire thread but pay attention to #4 and #5.
And the following link lists some options (See the section labeled "UTF-8 to ANSI in description").
http://utf.softwaresea.com/Windows-software-download/utf-8-to-ansi
Overall, you will most likely need to try and test the various converters and command line options that are available.
Hopefully there will be some code or converter that...
As I understand your post you need/want a utf8 to ansi converter.
Google accordingly and you will find many links.
Here is a link that applies Powershell:
https://community.spiceworks.com/topic/2133962-convert-txt-utf-8-to-ansi
However details matter and you should (no matter what method or conversion process you use) set up a test environment that protects the original files from harm if the conversion goes astray.
I.e., practice on copies of the files.
Tnx . But that now work for me . I need a simple tool or command . Please Help
Hopefully there will be some code or converter that will meet your requirements.
Do remember to test on copies of the data in an environment that keeps the original data file safe.
