Hi, i can't figure out what is causing unexpected shutdowns of pc.
I thought it might be cause of the temperature, they where around 50-55 for CPU and 65 for GPU while playing games. So i bought new cooler for CPU, zalman similar to 212evo it works perfectly temps are around 35.
Anyway pc still powers of like a light bulb and i can turn it on immediately after and it works just fine. It usually turns off after or while playing games rarely while browsing web.
I got no idea whatsoever what could be the cause, psu was once also the issue and i replaced it for some not well-known brand.
Thanks for future help.
Pc spec:
Fx6300
Gtx 1050ti
Ga970ds3p
1xhyperx 4gb ddr3 and 1x 4gb ddr3 which im not sure of the brand
240gb patriot blaze ssd
750gb wd green
Pc spec:
Fx6300
Gtx 1050ti
Ga970ds3p
750gb wd green
