[SOLVED] Suggest a case for 60 dolars and under for this pc build
Looks count.
If you like the looks pf the Phanteks 300, go ahead and buy it.
The case allows two 140mm front intake fans which should be plenty for your parts.
Okay then ill add 2 140 mm fans in front and one 120 mm fan on the top of the case
I think the single 120mm rear exhaust is sufficient.
Whatever cooling air that comes in the front will exit somewhere, taking component heat with it.
The main purpose of the rear fan is to direct the airflow past the cpu cooler and the gpu,
A top fan will tend to divert that direction.
Still, if you have the fans, it is not so hard to try different arrangements and see if there is a difference.
