[SOLVED] Suggest me GPU for my build ryzen 7 3800x
FaneTheClutcher
32
I have ryzen 7 3800x, 32gb ddr4 3200mhz
my mobo is Gigabyte b450m h
My PSU is 800w so dont worry about that.
I will play csgo,fortnite on competitive settings (low) full hd.
I recommend the RX 6700 XT. It will give you very high-FPS at 1080p and it has 12GB of VRAM so it will be good for more than just that.
If you want cheaper, then get the RX 6600, RX 6600 XT or RX 6700 (if available).
For those games it really doesn't need the greatest gpu.
Some choices:
AMD: Radeon rx 6600 or 6650xt
Intel: Arc A750
Nvidia: RTX 3050
(I would personally go with the 6650xt).
Reactions: Why_Me
Well I do worry about that, because I can't remember seeing a decent quality 800 watt unit, 850 watt maybe. Are you sure it isn't that?
Either way, wattage means nothing. Because if that "800 watt" is an 800 watt CIT or Cougar bag of nails with 550 watts on its 12v rail, then you need to be shopping for a new power supply too.
What's the brand and model of this 800 watt power supply that we don't need to worry about?
