Hey there!
So, I've been experiencing issues with my PC that I believe to be down to the GPU. Alas, when doing some research, it seems that a GTX 1070 will JUST About not fit in my Zalman Z11. Also, since my current GPU (Although very old) seems to be having heat issues, I'm cautious about opting for the mini version with less fans.
Now, If I'm going to get a new case I'm going to have to do almost all the work of a brand new build anyway. Plus, if I'm wrong and my GPU isn't the issue, it will mean that my problems are much more likely to be fixed.
Ergo, assuming I was to replace my Case, motherboard, CPU and GPU all at once - Which of the first three would you recommend? What about pre-built Board+CPU combos, to save me from having to do the finnicky thermal paste, how big is the markup?
I'm looking to spend about... £800 in total? So -£400 for the GPU. I don't do very CPU intensive stuff, so as long as it can handle the 1070 then we're good.
My current build is as follows:
Zalman Z11 Case (I'm a sucker for Aesthetics and I'm not a Fan of Red. My mouse is blue, so that would be easiest, but everything else can change colour.
Samsung Pro Evo SSD 256 GB
WD Caviar black 2TB
Asrock Z77 Exteme4 Motherboard (Side note: I only use the built in sound card, but I very much enjoy my music, could I benefit from getting a dedicated card or is the difference small?)
Nvidia GTX 670
i5 3470
Corsair Vengeance ram (About 32GB)
At current, I have about 5 fans and a coolermaster (I can't remember the name. It's just a metal heat sinks with 2 fans either side). I haven't noticed high CPU temperatures ever, so I don't think I need water cooling atm unless you insist. I'm more concerned with GPU temps.
Thanks in advance!
EDIT: I realise £800 might be a bit difficult. But I think below £900 is definitely achievable, unless I've forgotten what a good motherboard costs.
WD Caviar black 2TB
Nvidia GTX 670
i5 3470
Thanks in advance!
