Suggestions for an ATX case that is 16" tall
Etta79
9
So, this is probably the dumbest rookie mistake ever, but I bought all of my components... then I bought a desk. I put together my desk without even thinking about whether or not the case would fit where it needs to go.
Well, needless to say, I laid out all of my parts and thought -- holy crap, the case looks huge. It will not fit and it HAS to fit in a particular spot. I am bummed because I liked the look of this case, even though it was a lot larger than I expected -- I should have looked at the measurements of my desk, but it is too late now. 🙁
So... I now need to return this case a.s.a.p. and get a shorter one -- Anyone have any suggestions for a case that is 16"-16 1/2" tall and will fit my parts? I wanted one with a window (left panel) so I could drool over my handiwork, but can forgo the luxury, if it's impossible to find.
Here is the list of the parts that I have. I'm frantically searching for something that I like the look of , as you read. I know it is a lot to ask to find a case of a specific height to fit parts already on hand, but any help would be very appreciated!
edited to add: The height of the area I would like to place the case is 17 3/4" so I am assuming anything 16 1/2" or less will have enough air flow. It would be open on the front and left side and only partially closed on the right side and top.
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor (Purchased For $239.99)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (Purchased For $39.99)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste (Purchased For $6.99)
Motherboard: Asus Z87-PRO ATX LGA1150 Motherboard (Purchased For $194.99)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory (Purchased For $84.99)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Disk (Purchased For $80.99)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (Purchased For $64.99)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (Purchased For $59.99)
Video Card: EVGA GeForce GTX 770 2GB Video Card (Purchased For $380.94)
Case: Fractal Design Arc Midi R2 (Black) ATX Mid Tower Case (Purchased For $99.99)
Power Supply: Corsair Enthusiast 650W 80+ Bronze Certified Semi-Modular ATX Power Supply (Purchased For $99.99)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer (Purchased For $19.99)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) (Purchased For $99.99)
Monitor: Asus VE248H 24.0" Monitor ($170.11)
Keyboard: Razer DeathStalker Wired Gaming Keyboard (Purchased For $0.00)
Other: Rosewill RTK-045 45 Piece Premium Computer Tool Kit (Purchased For $21.72)
Other: Intel Sega Gift - Total War: Rome II [Online Game Code] Free w/ purchase (Purchased For $0.00)
Total: $1665.65
(Generated by PCPartPicker 2014-03-07 14:33 EST-0500)
TLDR: Basically, I need to find a case that is 16 1/2" or less and that will fit my parts listed above.
It wouldn't be optimal, but I guess it's acceptable. If you could really trade that desk for one that is a tad higher that'd be great.
Anyway, I have found this one: http://pcpartpicker.com/part/rosewill-case-galaxy03
I am still searching for more cases, basically opening random Mid-Tower ATX cases with good ratings until one that meets the specs shows up.
Current list:
http://pcpartpicker.com/part/rosewill-case-galaxy02
Edit: And that's it. Those two are the only two cases with reasonable cooling and rating above 2.0 (both have 4.0 out of 5).
Does that height include room for air to flow through the top? If the case has openings at the top for airflow (which most cases do) it would be obstructed it if were the same height as the opening you want to place the case in.
The height of the opening is just over 17 3/4". Would a case 16 1/2" or less have enough air flow? It would be open on the front and left side and only partially closed on the right side and top. Basically the case needs to fit under the hutch area of my L-shaped desk (hutch on right).
Current list:
Well, thank you so much for taking time out of your day to look. I looked too and found nothing. I did however measure the space "under" the desk and since it's mostly open under there, I think I can put the case on the floor (or, even better -- make a platform and put wheels on it). I won't be able to look at it, but it will have plenty of airflow and be safely tucked away.
