Question Suitable GPU that I can pair with my current system ?
Omaiwa
Commendable
Aug 13, 2019
46
I was planning to buy a GPU but I don't know what is the best GPU i can pair up with my current set-up and a GPU that is a friendly budget
SPECS:
Motherboard: GA-A320M-S2H V2
CPU: AMD Ryzen 3 3200G
RAM: 2x8gb HyperxFury 2666MHz
PSU: SMART RGB 600W
While I generally wouldn't recommend a 4GB card today, on a card with the performance of a 1050 Ti It most likely wouldn't matter. You'd be limited by the performance of the card before you run out of memory. Heck, I can't get the 6GB on my 1060 fully loaded without dropping to unplayable framerates.
The 4 GB 1050 Ti should be fine.
How about the GTX 1650 4GB is it okay to pair up with my current cpu and mobo? will it bottleneck?
