Superposition benchmark temps
aamird95
20
Did a superposition benchmark test with my 2080ti , 8700k and the temps are at min 37c and max 69c , is that normal ? What is the safe side my gpu should always stay in ? (Gpu was at stock and so was the cpu)
Which temps are 37-69'c? CPU, or GPU? Or both? In Superposition, I'm assuming the GPU.
It's going to depend on the cooling solution (and airflow). The lower the temps, the better to achieve higher boost clocks etc. But 80'C is pretty typical for the 2080TI from what I've seen, and the max 'safe' temp as per Nvidia is 89'C
https://www.nvidia.com/en-gb/geforce/graphics-cards/rtx-2080-ti/
