Surface Pro 7, i5 / 8GB / 128 GB, out of warranty. Fully charged, I took it off the charger, using it for tuning/logging my car for 30 minutes and about 15 minutes of web surfing. I didn't look at the battery life, but no reason there wasn't plenty left as I've used it for these activities for far longer without an issue.
Closed the Type Cover for about 5 minutes. Open it back up and nothing. Tried the following (and several times for each):
Type Cover does not light up. Surface was not dropped. It was not overheated in the least. It worked all day without issue.
Any other ideas? I use this thing a lot and need it. MS wants $450 to swap it out - which isn't happening as I'm done with the Surface if I can't get this one running again
- Power for 30+ seconds. Also tried for a couple of minutes straight
- Power + Volume Down for 30+ seconds and for a minute
- Power + Volume Up for 30+ seconds
- Power + Volume Up + Volume Down for 30+ seconds
- Charging for a couple of hours, then trying the above, both while plugged in and not. Charger power light is solid
- Removing the only things attached (MicroUSB card and Type Cover) and trying the above
