The only audio output my projector
ViewSonic PJD7828HDL 3200 Lumens 1080p HDMI Home Theater Projector https://www.amazon.com/dp/B01A6UNGXQ/ref=cm_sw_r_cp_apa_H7Y-BbTWRZEMC
has natively is 3.5mm headphone. I plan to input a firetv stick into an HDMI audio extractor
ESYNIC 1080P HDMI Audio Extractor HDMI to HDMI + Optical TOSLINK SPDIF + Analog RCA L/R Stereo Audio Video Splitter Adapter Converter for Blu-ray Player Xbox PS3 PS4 https://www.amazon.com/dp/B06VVTQY8D/ref=cm_sw_r_cp_apa_i4Y-BbEPHX2CW
and then input to the HDMI on the projector. I would then have the option of optical or LR rca audio out from the extractorr. If I bought a 2.1 or 5.1 speaker set for example and plugged the optical wire into it would I get true surround sound or do I need to plug into some type of receiver first?
Also the HDMI splitter specifies it doesn't support Dolby digital Plus...will this be a huge issue?
Also looking for recommendations on speakers/equipment between 200-500$
Thank you to anyone able to help
